Oliver_Hauck
### USB JTAG driver installation problem on Ubuntu Linux 18.04.4 LTS ###
I need to access USB JTAG on a VCU129 Eval board from Ubuntu 18.04.4 LTS.
I downloaded and installed the rather dated install_drivers tar ball.
Here is top of readme:
** c2005-2008 Xilinx, Inc. All Rights Reserved.
** Confidential and proprietary information of Xilinx, Inc.
** ____ ____
** /___/ \ / Vendor: Xilinx
** \ \ \/ Version: 1.053
** \ \ Filename: readme.txt
** / / Date Last Modified: Tue Mar 4 2008
** /___/ /\ Date Created: Tue Mar 4 2008
** \___\/\___\
**Device:
**Purpose:
** Linux driver installer for the Xilinx Parallel IV and Platform Cable USB
** download cables.
**Reference:
**Revision History:
** 1.033: Cd to the install_drivers directory.
** 1.035: Add check for write permission to the install_drivers directory.
** Updated windrvr6 to version 9.00.
** Used modprobe in loading the xpc4drvr 2.6 driver.
** 1.051: Added support for xp2 and xse.
** 1.052: Fixed version of xusbdfwu.rules
** 1.053: Unset ARCH environment variable prior to building drivers.
I installed fxload package and then started install_drivers script.
However it failed, see att. photo.
Is this at all the correct download, or is there something newer ?
Currently I'm not even using Xilinx platform cable but just need to program VCU129 via USB JTAG.
What am I doing wrong here ?
Tags (3)
hj
Vivado installation comes with the drivers. Try to install them again.
1. Follow the AR https://www.xilinx.com/support/answers/54381.html debugging steps. See if that helps.
2. Following user guide has the steps as well https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug973-vivado-release-notes-install-license.pdf#page=36
For more information please refer to configuration resources https://forums.xilinx.com/t5/FPGA-Configuration/Configuration-Resources/m-p/753763/highlight/true#M5891
