Visitor abdul_syed
USB connection configuration iMPACT on VM Oracle Linux (Spartan 6 Nexys 3 board)
Hi all,
I am trying to connect to the Spartan 6 evaluation board Nexys 3 with the iMPACT tool (VM Oracle) as it doesn't recognize the USB connection to the evaluation board. See the attached screenshot.
Please can you advise me how I can configure the USB interface on the VM Oracle so that it recognize the USB connection.
Many thanks
Re: USB connection configuration iMPACT on VM Oracle Linux (Spartan 6 Nexys 3 board)
Hi @abdul_syed
Information provided in links below, may solve your issue:
https://www.xilinx.com/support/answers/68233.html and https://www.xilinx.com/support/answers/68433.html
Bhushan
Bhushan
Visitor abdul_syed
Hi @bpatil
I cannot pass through the USB connection on the VM Oracle 5.1.30 Linux. When I try to manually select the USB connection by clicking on the USB connection on the bottom left corner of the VM Oracle environment and selecting the 'Digilent Development board JTAG'. The following error message is shown (see the attached image) 'the USB connection is busy with the previous request please try later'.
I also tried installing the extension pack for the USB 2.0 from VM Oracle website.
I hope you can assist me in resolving this issue.
abdul_syed
Hi @abdul_syed
This link may help you!!
Bhushan
Bhushan
Visitor abdul_syed
Hi @bpatil
I am sorry but I cannot solve this issue and am struggling to pass through the usb connection on the Oracle VM on windows 10 OS.
I am not sure what I can do, I tried creating a new filter and also tried manually forcing the USB to connect to the DIgilent USB connection (by right clicking on the bottom and selecting DIgilent USB Cable) but no luck.
Please can you advise me how I can overcome this problem.
Can you provide me a Xilinx ISE for Windows 10 which does not require Linux OS?
Many thanks,
Hi @abdul_syed
Check https://forums.xilinx.com/t5/Configuration/ISE-14-7-cable-connection-problem/td-p/883918 and https://forums.xilinx.com/t5/Configuration/14-7-ISE-VM-and-XIL-IMPACT-SKIPIDCODECHECK-1/td-p/880479
Bhushan
Bhushan
Visitor abdul_syed
Hi @bpatil
I have read through the USB pass through explained the forum below;
Apparently this link is not working or does not exist;
Can it kindly be possible if you could kindly perform an installation on a windows 10 machine with the Xilinx ISE webpack and identify the steps which are required to pass the USB connection. It would be greatly appreciated if you could kindly perform this test.
Many thanks,
Abdul
Hi @abdul_syed
Check https://forums.xilinx.com/t5/Configuration/14-7-ISE-VM-and-XIL-IMPACT-SKIPIDCODECHECK-1/m-p/880479/highlight/true#M9593
Bhushan
