06-08-2018 01:25 AM
I want to access an external spi-flash memory through a custom flash controller at a Kintex UltraScale XCKU115-FLVA1517.
The controller works fine with different FPGAs of the 7series. In the UltraScale Design I entcounter a problem when I try to add the configuration ports to the constraints file:
Pin AB9, AE11, AD10, AC9, AD9 should be the dedicated configuration pins of the xcku115-flva1517. The relevant section of my constraints file is as follows:
set_property PACKAGE_PIN AB9 [get_ports qspi_config_spi_csn] set_property IOSTANDARD LVCMOS33 [get_ports qspi_config_spi_csn] set_property PACKAGE_PIN AE11 [get_ports {qspi_config_spi_d[0]}] set_property IOSTANDARD LVCMOS33 [get_ports {qspi_config_spi_d[0]}] set_property PACKAGE_PIN AD10 [get_ports {qspi_config_spi_d[1]}] set_property IOSTANDARD LVCMOS33 [get_ports {qspi_config_spi_d[1]}] set_property PACKAGE_PIN AC9 [get_ports {qspi_config_spi_d[2]}] set_property IOSTANDARD LVCMOS33 [get_ports {qspi_config_spi_d[2]}] set_property PACKAGE_PIN AD9 [get_ports {qspi_config_spi_d[3]}] set_property IOSTANDARD LVCMOS33 [get_ports {qspi_config_spi_d[3]}] set_property CFGBVS VCCO [current_design] set_property CONFIG_VOLTAGE 3.3 [current_design]
Do I miss something? Is there something different between UltraScale and 7series which might be relevant for my problem? Do I need some additional constraints to access the dedicated configuration pins with UltraScale?
Thanks in advance.
Jan
06-08-2018 04:13 AM
in ultrascale the spi data pins d0 to d3 are in dedicated bank, so to use in your design you need to use startupe3 primitive
check the following
06-08-2018 03:58 AM
@jhk These are Dedicated Config Pins and cannot be user assigned. Check Page#27-28 of UG575. The pins you trying to lock are part of Bank 0.
Are you sure you were doing it in 7-series? I believe you were locking them to Multi-function pins and not Dedicated pins in bank 0 of the 7-series device.
06-08-2018 04:13 AM
check the following
06-08-2018 04:24 AM
@gnaraharthanks for your reply.
You are right. UG575, p.28 says that the data pins and chip-select are dedicated for UltraScale whereas the corresponding pins in a 7series device are multi-function (UG475, p.27). I was able to access the configuration flash via my custom spi-controller with a XC7VX485T and some 7series Artix devices.
Jan
06-08-2018 04:26 AM
