jhk
Ultrascale Configuration Pins - not a valid pin name
I want to access an external spi-flash memory through a custom flash controller at a Kintex UltraScale XCKU115-FLVA1517.
The controller works fine with different FPGAs of the 7series. In the UltraScale Design I entcounter a problem when I try to add the configuration ports to the constraints file:
Pin AB9, AE11, AD10, AC9, AD9 should be the dedicated configuration pins of the xcku115-flva1517. The relevant section of my constraints file is as follows:
set_property PACKAGE_PIN AB9 [get_ports qspi_config_spi_csn]
set_property IOSTANDARD LVCMOS33 [get_ports qspi_config_spi_csn]
set_property PACKAGE_PIN AE11 [get_ports {qspi_config_spi_d[0]}]
set_property IOSTANDARD LVCMOS33 [get_ports {qspi_config_spi_d[0]}]
set_property PACKAGE_PIN AD10 [get_ports {qspi_config_spi_d[1]}]
set_property IOSTANDARD LVCMOS33 [get_ports {qspi_config_spi_d[1]}]
set_property PACKAGE_PIN AC9 [get_ports {qspi_config_spi_d[2]}]
set_property IOSTANDARD LVCMOS33 [get_ports {qspi_config_spi_d[2]}]
set_property PACKAGE_PIN AD9 [get_ports {qspi_config_spi_d[3]}]
set_property IOSTANDARD LVCMOS33 [get_ports {qspi_config_spi_d[3]}]
set_property CFGBVS VCCO [current_design]
set_property CONFIG_VOLTAGE 3.3 [current_design]
Do I miss something? Is there something different between UltraScale and 7series which might be relevant for my problem? Do I need some additional constraints to access the dedicated configuration pins with UltraScale?
Thanks in advance.
Jan
kkn
in ultrascale the spi data pins d0 to d3 are in dedicated bank, so to use in your design you need to use startupe3 primitive
check the following
https://www.xilinx.com/support/documentation/application_notes/xapp1280-us-post-cnfg-flash-startupe3.pdf
gnarahar
@jhk These are Dedicated Config Pins and cannot be user assigned. Check Page#27-28 of UG575. The pins you trying to lock are part of Bank 0.
Are you sure you were doing it in 7-series? I believe you were locking them to Multi-function pins and not Dedicated pins in bank 0 of the 7-series device.
- Giri
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
kkn
check the following
jhk
@gnaraharthanks for your reply.
You are right. UG575, p.28 says that the data pins and chip-select are dedicated for UltraScale whereas the corresponding pins in a 7series device are multi-function (UG475, p.27). I was able to access the configuration flash via my custom spi-controller with a XC7VX485T and some 7series Artix devices.
Best regards,
Jan
jhk
@kknthanks for your reply.
I will have a look at the XAPP1280 Application Note.
Best regards,
Jan
