Ultrascale+ readback capture issue
Hi All,
I am trying to perform readback capture on VCU118 (XCVU9P).
I do that through ICAP by the use of embedded logic.
I am quite familiar with this process through Virtex5/6.
My observations on US+ are:
  1. issuing SHUTDOWN command - causes implementation to hang-out
what exactly do SHUTDOWN command (there is no way to get to know this from UG's) and is it necessary to perform readback capture ???
if I omitt SHUTDOWN command - performing reading from configuration memory doesn't hang the implementation
2. In the readback capture without issuing SHUTDOWN reading from particular address for seeking for a bit indicated in .ll file(Logic Location file) - frame address and offset, it seems to the bitstream doesn't correspond to registers values I know well and have possibility to change their states. I am preety sure that I am reading exactly bit of interest (use Chipscope)
I know there is different way in US+ to perform Capture CTL/MSK regs but it seems like it don't work.
are there any other factors (xdc attributes) that can influence mismatch between readback bitstream and Logic Location file ?
I know XAPP1230 and the way of performing readback via JTAG and reading whole configuration memory rather than particular frame.
Is ICAP in some kind of way defective for that purpose?
I keep MCAP disable.
Reading for example in that way IDCODE returns perfect value
please answear if someone is interested in this topic.
we can do further investigation .
thanks
Łukasz Matoga
