Unable to Connect USB Parallel II Cable
Unable to connect USB Parallel II Cable via iMPACT with a Xilinx SP605 board. I understand that it is not supported with Windows 10, however it was working fine earlier this year though it just stopped working. When I plug the USB cable into the computer (plugged into the JTAG port on the evaluation board) windows says it doesnt recognize the USB.
Hi @Entropy ,
Please refer this https://forums.xilinx.com/t5/Design-and-Debug-Techniques-Blog/Quickly-install-Cable-Drivers-for-Xilinx-Platform-Cable-USB-II/ba-p/1013230 which will help you.
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
I have gone through the suggested fix, however I'm still unable to connect.  Here is the console window output from iMPACT.
PROGRESS_START - Starting Operation.
Connecting to cable (Usb Port - USB21).
Checking cable driver.
Source driver files not found.
The Platform Cable USB is not detected. Please connect a cable.If a cable is connected, please disconnect
and reconnect to the usb port, follow the instructions in the 'Found New Hardware Wizard', then retry
the Cable Setup operation.
PROGRESS_END - End Operation.
Elapsed time = 0 sec.
Server Name = localhost, Port = 50001.
INFO:iMPACT - Client connected to Server: localhost, Port: 50001.
INFO:iMPACT - Connecting to cable (Usb Port - USB21).
INFO:iMPACT - Checking cable driver.
INFO:iMPACT - Driver file xusb_emb.sys found.
INFO:iMPACT - Driver version: src=1029, dest=1029.
INFO:iMPACT - Driver windrvr6.sys version = 10.2.1.0.INFO:iMPACT - WinDriver v10.21 Jungo (c) 1997 - 2010 Build Date: Aug 31 2010 x86_64 64bit SYS 14:14:44, version = 1021.
INFO:iMPACT - Cable connection failed.
GUI --- Auto connect to cable...
AutoDetecting cable. Please wait.
Connecting to cable (Parallel Port - LPT1).
Your driver installation is not complete. Please re-run your application or run
install_drivers.exe from the ISE installation area as an Administrator to complete the driver installation.
Service using windrvr6.sys : SYSTEM\CurrentControlSet\Services\WinDriver6.
ImagePath = \SystemRoot\system32\drivers\windrvr6.sys.
Start = 3.
ErrorControl = 1.
Type=1.
Connecting to cable (Parallel Port - LPT2).
Start = 3.
ErrorControl = 1.
Type=1.
Connecting to cable (Parallel Port - LPT3).
Start = 3.
ErrorControl = 1.
Type=1.
Connecting to cable (Parallel Port - LPT4).
Start = 3.
ErrorControl = 1.
Type=1.
Elapsed time = 2 sec.
Cable autodetection failed.
WARNING:iMPACT:923 - Can not find cable, check cable setup !
Downloaded the latest ISE Project with virtual box and able to connect to my SP605 board.
Have you configured the Virtual box as instructed in UG1227 page#22 https://xilinx.com/support/documentation/sw_manuals/xilinx14_7/ug1227-ise-vm-windows10.pdf
You can try these steps as well: https://www.centennialsoftwaresolutions.com/post/connecting-vivado-to-digilent-s-usb-to-jtag-through-virtualbox
