Unable to program an SPI memory flash
When trying to program an ISSI flash part using Vivado 2018.3 hardware manager, I get the following error:
[Labtools 27-2251] Unable to read device properties. Please make sure that the proper configuration memory part is selected.
After scoping the communication lines, we found out that the FPGA sends the right clock signal (3MHz) and it activate CS signal (it goes to 0 since it is active low) but there is no communication activity on DQ0 or DQ1. Both signals read 0 volt. Attached is a scope screenshot (C1: CLK, C2: DQ0 and C3: CSbar). Not sure why the FPGA is NOT sending data and I could you some help here. Below is some info about my design:
FPGA: XC7S25-1CSGA225C
Flash: IS25LP016D-JKLE-TR
Configration voltage: 3.3V
Configration rate: 3MHz
Configration width: 4xSPI
And here is the XDC constraints related to the configration settings
set_property BITSTREAM.CONFIG.CONFIGRATE 3 [current_design]
set_property CONFIG_VOLTAGE 3.3 [current_design]
set_property CFGBVS VCCO [current_design]
set_property BITSTREAM.CONFIG.SPI_BUSWIDTH 4 [current_design]
set_property CONFIG_MODE SPIx4 [current_design]
回复: Unable to program an SPI memory flash
1. Did you correctly select  IS25LP016D in GUI?
2. Is there any other warning issued during the programming process?
3. What if you generate a x1 file and try to program it? Please check if this is successful.
I've been helping debug this issue.
1) Correct device is selected
2) No other warning detected. When the program_hw_cfgmem command is issued, the data returned is all 0's for Mfg Id, Mem Type, Mem Capacity, Device ID 1/2,
3) We tried x1 without success
Then try to erase the flash, does same error message occur? If so, check the schematic first and see if there is some wrong connection between FPGA and SPI.
You can use this vivado and cable to download bit to fpga right? Did you encoutner any SI/CRC issue?
We get the same error when erasing the flash.
Schematic was checked by both xilinx and ISSI.
We can use both vivado and xilinx SDK to download the bit file and run the code but we can't program use the flash.
Please share the flash + FPGA schematic I will check those. Probe the prog_b, init_b, FCS_B. Is PUDC_B connected? Or floating?
Above flash is supported and tested for this device so there has to be some HW related issue. How many boards are showing this behavior?
Harshit
Harshit,
Happy to share the full schematic if I can get a private email address. For now I attached screenshots of the connections in question. Let me know if you see anything you don't like. This issue happned on all three boards we tested so far.
Thanks!
Mustafa
To update this project:
Tried on both 2018.3 and 2019.1 - no change
Customer loaded sample bitstream in FPGA to toggle MOSI pin to verify it is not shorted. This test was successful.
Customer shipped platform to FAE to recreate error. FAE witnessed similar results.
QUESTION: Has Xilinx confirmed the IS25LP016 can program a Spartan 7 device? What device/tool combinations were used in the validation process?
Are there other low level commands/mechanisms for Vivado/HW manager to bit bang or interrogate the FLASH? We do not see data out of MOSI line.
Please advise.
Neil
Any update on this? We are still not functional.
We believe we have found an issue in the lastest version of the schematic.
Just to add. We did the recent testing again after seeing this issue. Above flash is fully supported and works with Vivado version which you are using.
