Visitor sichu_m
Unable to program my FPGA Spartan 6 on ISE 14.07 (Ubuntu 18.04)
WARNING:iMPACT:923 - Can not find cable, check cable setup !
I ge this message, now the weird thing is that I am able to program it on Windows 10 with ISE installer that is given on Windows.
When I program the FPGA on Windows 10, it says that the connected cable is
Diligent JTAG-HS2 Programming Cable
I followed the following tutorial and I did all of the steps that were provided here :
https://www.youtube.com/watch?v=meO-b6Ib17Y
For driver installation:
1. Run the following commands:
sudo /opt/Xilinx/14.7/ISE_DS/ISE/bin/lin64/install_script/install_drivers/./install_drivers
(This will give error code 1. Don't worry about it.)
cd /opt/Xilinx/14.7/ISE_DS/ISE/bin/lin64/digilent/
sudo ./install_digilent.sh
sudo apt-get install gitk git-gui libusb-dev build-essential libc6-dev-i386 fxload libftdi-dev
cd /opt/Xilinx/14.7
sudo git clone git://git.zerfleddert.de/usb-driver
cd usb-driver
sudo make (Use make for both 32-bit and 64-bit)
./setup_pcusb /opt/Xilinx/14.7/ISE_DS/ISE/
For making IMPACT work (To solve WARNING:iMPACT - Module windrvr6 is not loaded.):
1. Run the following command: export LD_PRELOAD=/opt/Xilinx/14.7/usb-driver/libusb-driver.so or add this command in ~/.bashrc. This is known to cause issues with Xilinx SDK, so open xsdk from different terminal window in which LD_PRELOAD isn't exported (you will need to comment this line, if added in ~/.bashrc for Xilinx SDK). You can also make a script which does this for you. ;)
Re: Unable to program my FPGA Spartan 6 on ISE 14.07 (Ubuntu 18.04)
Neither Ubuntu nor Win10 is officially supported by ISE, plus a clone cable.
https://www.xilinx.com/support/answers/18419.html
Yes it might work some times but we cannot guarantee that nor support that.
To program S6, I suggest you turn to ISE on a supported OS. Don't waste time on this; it may takes just a few moments to solve or it will take forever.
回复: Unable to program my FPGA Spartan 6 on ISE 14.07 (Ubuntu 18.04)
Where did you get the cable?
Visitor sichu_m
I got it from Ebay, but I don't think that there is a problem with the cable because it works perfectly on Windows 10.
Scholar drjohnsmith
The report says its a Digilent HS2,
which looks like this
https://store.digilentinc.com/jtag-hs2-programming-cable/
looks to me like you have an illegal clone of the HS2,
    Yo had better get back to where you purchased it from for support.
Visitor sichu_m
Oh okay, thanks for the help. I will use Windows 10 for now until it stops working.
Thank you for your time!
