Thomas
Usage of FPGA differential pins on Zynq-7010
Hello everyone,
I am currently working on microZed, and I would like to externalize FPGA signals to zynq FPGA pins.
The thing is, most FPGA pins (bank 35) are differential ones, whereas my signals are not.
How should I deal with it ? Should I make my signals differential ?
Thanks for any help,
Thomas.
bruce_karaffa
You may use any of the IO pins as single ended.
bruce_karaffa
IO pins may be used for either differential or single ended signals. The names in the tables must reflect which pairs of pins need to be used for a differential signal.
Thomas
The thing is, I only see two single-ended pins in bank 35 : JX2_SE_0, JX2_SE_1. (I may be wrong here)
I need more single-ended pins for all my fpga signals, how can I overcome that?
bruce_karaffa
Thomas
ok thank you !
