Participant prashanth_makam
Using of Configuration flash and calculation checksum in 7 series
Previously I am using S25FL032P0XMFI018 for Configuration flash in SPI MODE but flash part is absolute in my design for my Artix-7 FPGA so,i thought of replacing Flash IC to IS25LP032D-JNL(A3) in QSPI  i would like to know whether IC is supported by Xilinx and also i need to know how to Calculate checksum by accessing flash
Re: Using of Configuration flash and calculation checksum in 7 series
Yes it is supported by Xilinx 2019.2 tools and devices. Refer to the UG908 https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_2/ug908-vivado-programming-debugging.pdf
Once you program the flash Vivado will print the checksum.
-Harshit
I need to calculate checksum manually
Previously I am using S25FL032P0XMFI018 for Configuration flash in SPI MODE but flash part is absolute in my design for my Artix-7 FPGA so,Please help me with a new flash chip supported in QSPI  i would like to know whether IC is supported by Xilinx and also i need to know how to Calculate checksum by accessing flash
