Vivado 2016.2: AR# 61312 fix no longer works
I recently updated from 2015.4 to 2016.2, and now I can't connect to the JTAG chain on my PCB.  This chain has multiple devices, and I've been using the work-around covered in AR# 61312 since 2014.2 came out.  Also, Vivado 2016.2 does not auto-detect my chain.
Thanks in advance.
Scholar pratham
Re: Vivado 2016.2: AR# 61312 fix no longer works
@scb_macb I will check on this and get back to you.
-Pratham
@pratham,
Here is my JTAG chain:
Device 1)  xc7vx690t
Device 2) atmel microcontroller (uc3a0512)
Device 3) SRIO switch (idt cps1616)
Device 4) SRIO - PCI-X bridge (idt tsi721)
Newbie tmouli
Have you found any solutions for this? I am running into similar problem...
