Vivado 2018.2 BBRAM programming fails when targeting KU040 device
BBRAM key programming is failing for a KU040 device with the below error message:
ERROR: [Labtools 27-3105] HW Server Error: Fuse Key CRC does not match
Re: Vivado 2018.2 BBRAM programming fails when targeting KU040 device
Hi traian.neacsa@cetti.ro
In Ultrascale devices we cannot readback encryption key through JTAG.
When a key is written to the device via JTAG, a key integrity check is initiated by writing the expected CRC32 value via JTAG to the device. An actual CRC32 integrity check is calculated on the stored key by the device (internally) and compared to the expected CRC32 that was just received via the JTAG port.
It seems, you are getting this message due to mismatching of CRC32 value.
Try reducing JTAG clock rate (TCL command: set_property PARAM.FREQUENCY 3000000 [get_hw_targets]) and check for AR#68832.
Also try debugging as per check list provided at XAPP1267 (v1.1) (Page 22)
Bhushan
Bhushan
Bhushan
Bhushan
Do i have to erase SPI flash (with encrypted bitstream) before reprogram BBRAM key  ? BBRAM key was cleared by software before triggering IPROG command using ICAP !
If you are changing BBRAM key then you need to create encryption bitstream accordingly and need program it in SPI flash (I believe you are performing FPGA configuration through SPI flash)
Bhushan
Bhushan
Thank you Bhushan !!!
