Papcsi
W25Q32JVSSIQ and an MCS file
I have to program a W25Q32JVSSIQ chip withe a *.mcs file. I've got a Xilinx Platfor Cable USB II, but I dont know how can I do it. ( I dont have too much programming experience)
Can I program these components after the placement someohow? Can I do it with this equipment at all?
Any advice would be greatly appreciated
Papcsi
hj
You can find the list of supported Flash Memory Devices for Xilinx devices Configuration in UG908 (v2020.2) https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_2/ug908-vivado-programming-debugging.pdf
Please make sure to check the latest version of UG908. Vivado only supports Micron, ISSI, Macronix, and Spansion flashes.
For all other flash devices, you need to use 3rd party programmer to configure your flash.
For more information please refer to configuration resources https://forums.xilinx.com/t5/FPGA-Configuration/Configuration-Resources/m-p/753763/highlight/true#M5891
