WebPAK 14.7, IMPACT, verification fails
Baseline:running ISE WebPACK 14.7 on Win 10 64-bit with Digilent JTAG-USB cable. Attempting to program XC9572XL-Q44.
Initially having problem with iMPACT crashing, as described in this post. However, it seemed I could get things working by running iMPACT in batch mode, and apprears I can successfully program, but not verify. Some of the CPLD functionality seems to be working, but not all, and can't tell if it's a failure to program properly. Have tried two different JTAG-USB cables, same result.
I can connect, erase, blank check (passed), program, blank check (fails - as it should, just programmed it), but then fails to verify.
Below is the transcript of the programming session. Any idea why the verify fails? Possibly an unsupported function of the Digilent JTAG-USB cable (although I have not found anything to indicate that is the case)?
FOLLOW-UP: I also followed the suggestions in this post of not having the project path include spaces, and strangely enough, the CPLD appears to be working after programming (path is now C:\Xilinx\CPLD7000). Verification still fails, so still looking for an answer to that.
Paul
C:\Xilinx\14.7\ISE_DS>impact -batch
Release 14.7 - iMPACT P.20131013 (nt64)
Copyright (c) 1995-2013 Xilinx, Inc.  All rights reserved.
Preference Table
Name                 Setting
StartupClock         Auto_Correction
AutoSignature        False
KeepSVF              False
ConcurrentMode       False
UseHighz             False
ConfigOnFailure      Stop
UserLevel            Novice
MessageLevel         Detailed
svfUseTime           false
SpiByteSwap          Auto_Correction
AutoInfer            false
SvfPlayDisplayComments false
>setMode -bs
>setCable -port auto
INFO:iMPACT - Digilent Plugin: Plugin Version: 2.4.4
INFO:iMPACT - Digilent Plugin: found 1 device(s).
INFO:iMPACT - Digilent Plugin: opening device: "DCabUsb", SN:50003C010788
INFO:iMPACT - Digilent Plugin: User Name: DCabUsb
INFO:iMPACT - Digilent Plugin: Product Name: JTAG-USB Cable
INFO:iMPACT - Digilent Plugin: Serial Number: 50003C010788
INFO:iMPACT - Digilent Plugin: Product ID: 30100203
INFO:iMPACT - Digilent Plugin: Firmware Version: 030A
INFO:iMPACT - Digilent Plugin: JTAG Port Number: 0
INFO:iMPACT - Digilent Plugin: JTAG Clock Frequency: 1600000 Hz
>Identify -inferir
Identifying chain contents...'0': : Manufacturer's ID = Xilinx xc9572xl, Version : 5
INFO:iMPACT:1777 -
   Reading C:/Xilinx/14.7/ISE_DS/ISE/xc9500xl/data/xc9572xl.bsd...
INFO:iMPACT:501 - '1': Added Device xc9572xl successfully.
done.
Elapsed time =      0 sec.
>identifyMPM
>assignFile -p 1 -file "TopCPLD7244.jed"
'1': Loading file 'TopCPLD7244.jed' ...
done.
>erase -p 1
Maximum TCK operating frequency for this device chain: 0.
Validating chain...
Boundary-scan chain validated successfully.
'1': Erasing device...
'1': Erasure completed successfully.
>blankcheck -p 1
Validating chain...
'1': Putting device in ISP mode...done.
'1': Performing blank check on device ...
'1': Device is blank.
'1': Blank check completed successfully.
>program -p 1
Validating chain...
'1': Programming device...
done.
'1': Programming completed successfully.
Elapsed time =      7 sec.
>blankcheck -p 1
Validating chain...
'1': Device is not blank.
>verify -p 1
Validating chain...
'1': Verifying device...'1': Verification failed'1': Verification terminated
回复: WebPAK 14.7, IMPACT, verification fails
ISE is not supported on Win 10.  https://www.xilinx.com/support/answers/62380.html Take a look at this and you can have a try.
Officially we only got a Spartan-6 Virtual Machine version of ISE for Win10.
