XPS custom xbd in AXI
Hi to all,
               I have a custom board using spartan-6 LX16 and I already have an xbd using mlpb bus and its working OK. Now I want to use AXI bus and Im trying to create another xbd using XPS. As template Im using the  Xilinx_KC705 xbd board as reference and here comes the error, for some reason XPS is not finding the xbd.
I tried with differents things, like:
1) changing the location of the folder (inside edk/boards)
2) using another templates
3) Try to use an older one version of XPS (yes - an older one of ISE 14.7)
I read this link https://forums.xilinx.com/t5/Embedded-Development-Tools/How-can-I-get-EDK-to-load-user-created-XBD-file/mp/10879#M2621  but I already now how to create an xbd for MPLB bus.
Im using ISE 14.7 on Linux Tumbleweed. I only can use SP605-SP601-KC705 and another one more in AXI but I dont understand why XPS is not loading the custom xbd I have if I used the KC705 as reference.
Gastón
