Visitor eduray103
XQVU7P-1FLRA2104I Physical Characteristics
Hello.
I have a question about the physical characteristics of the XQVU7P-1FLRA2104I device.
What is the operating and non-operating temperature for this device in degrees celcuis? I've reviewed the product catalog and it is not in there. Thanks.
Re: XQVU7P-1FLRA2104I Physical Characteristics
Have you reviewed the device datasheet as well? https://www.xilinx.com/support/documentation/data_sheets/ds923-virtex-ultrascale-plus.pdf
--harshit
--harshit
In the data sheet,
Table 1 is the not be be exceeded (absolute max above which damage may/will occur), table 2 is the recommended stay within (below) operating.
The storage temperature maximum is in there somewhere as well, in any case it is hotter than 125C, but not by much.  Why anyone would have storage that hot, is just odd...
l.e.o.
