Visitor eyalo
XVC and vivado problem: 'refresh device' operation is stuck
Hi All,
I am trying to work with xcku115 (includes FT2232H) and XVC.
xvc server code (https://github.com/tmbinc/xvcd) with a small modification of setting
ftdi_set_bitmode(&ftdi, 0xFF, BITMODE_SYNCBB); - in the original code it uses CBUS which is not supported on this FTDI device.
I am able to connect to this device via the hw manager and even program the device.
The problem is that every "Refresh Device" operation is simply stuck forever.
Also after every programming , the vivado initiates a "Refresh Device" operation so even though the bit file was programmed, the vivado is stuck.
Did anyone encounter this?
Perhaps I need to set some specific baud rate/latency timer/something else?
I know that a lot of people are working with XVC in a stable way - wondering what am I doing wrong.
Thanks In advance.
Visitor eyalo
Re: XVC and vivado problem: 'refresh device' operation is stuck
Is there anyone from the Xilinx team that can address this post and provide some assistance?
Will be greatly appreciated.
Ronen L.
Visitor eyalo
Hi Again,
Is there anyone from Xilinx team that is tracking this forum? or is it a myth? :)
Even just a short reply of "checking this and will get back..." will due.
Ronen L.
Observer jxlannie
Hi,I met the same problem. Do you have sovled it? Could you share the experience?Thank you!
