Xilinx XCS350AN-TQG144 IN-FLASH MEMORY
We purchased Xilinx XCS350AN-5TQG144 for one of our projects. We chose this because of its internal flash memory as stated on the datasheet. I need help to access this in-flash memory because we did not include external flash memory on the board we designed. We need the FPGA to retain the program even after power off. Currently, the program is erased everytime the FPGA is power off.
Is it possible to make it non-volatile so that we don't need to reprogram the FPGA? Or we need to add external EEPROM or flash memory?
Khristofer
Re: Xilinx XCS350AN-TQG144 IN-FLASH MEMORY
Hi khristofer_marfa.m@xim-21
There is change of the in-system flash within the Spartan-3AN devices; there is possibility this may be causing issue in your case.
You have to apply patch to program the flash.
Check https://www.xilinx.com/support/answers/59572.html for more details.
Bhushan
Bhushan
Check mode select pins are set correctly, to make use of the internal flash
http://www.xilinx.com/support/documentation/user_guides/ug332.pdf (Chapter 10)
Bhushan
Bhushan
Hi Bhushan,
Thanks. Do you have sample coding for this? Or how to do it in ISE Design Suite 14.7.
Khristofer
Check for https://www.xilinx.com/support/documentation/user_guides/ug332.pdf (Page 223~233)
Bhushan
Bhushan
Do I still need to use external flash memory for this? Someone told me that I still need to use external flash memory. I am still confused. Do you have sample program where in you use the internal flash memory of FPGA and it became non-volatile?
Hi guys,
Please help. I am really stuck on my problem right now.
Please see the attached file for the code and schematic of my project.
If your design requires more space on flash than internal flash of FPGA; then only you need to use external flash.
Bhushan
Bhushan
Thanks. But can I ask for help if you can check the schematic and program if there is somethin I missed.
Also, can I ask for sample code in Verilog that  uses the in-flash memory of the FPGA?
Also, may I know how to use the program in the image.
Check for https://www.xilinx.com/support/documentation/application_notes/xapp1034.pdf to access the In-System Flash in the Spartan-3AN FPGA after the FPGA is configured.
Bhushan
Bhushan
Hi, I got this message when tried to open the Xilinx Platform Studio.
Any dstep by step help? I am a newbie on using FPGA. I am using ISE14.7. I really want to put the program on the in-flash memory so that I don't need to reprogram. Please help guys. Thanks. I am really still stuck.
Please help on this.
Is there anyone who can help?
Bhushan
Bhushan
Hi Bhushan,
It is already working now. Thanks for the help.
