Observer zhangxixi
ZCU102 Quad-SPI flash partial reconfiguration image question
I'm using ZCU102 to do partial reconfiguration project.
I have tested my partial reconfiguration IPs in JTAG mode and they work well.
Now, I'm moving bitstreams to SPI flash as its faster. I have several questions for making a boot image for SPI.
Q1. ZCU102 has a Quad-SPI Flash(ZCU102 page 33), therefore I can select interface as SPIx4 in "write memory configuration file".?  Here occur error:
[Writecfgmem 68-20] SPI_BUSWIDTH property is set to "1" on bitfile C:/UNET/PR/DSP_2/DSP_2.runs/impl_1/design_1_wrapper.bit. This property has to be set to "4" to generate a configuration memory file for the SPIX4 interface. Please ensure that a valid value has been set for the property BITSTREAM.Config.SPI_buswidth and rerun this command.
When I went back to design, I tried with TCL command "set_property BITSTREAM.CONFIG.SPI_BUSWIDTH 4 [current_design]".
Here occur error:
ERROR: [Netlist 29-69] Cannot set property 'BITSTREAM.CONFIG.SPI_BUSWIDTH', because the property does not exist for objects of type 'design'.
Resolution: Modify .xdc or RTL to not set this property or move it to one of the following object types that can accept this property: bd_intf_net,bd_cell,diagram,bd_port,bd_net
I also tried to "add properties" to my design, but there is no "BITSTREAM.CONFIG.SPI_BUSWIDTH" option (searching results here.)
several references I tried:
https://forums.xilinx.com/t5/Vivado-TCL-Community/BITSTREAM-CONFIG-SPI-BUSWIDTH-is-not-available/td-p/396801
https://forums.xilinx.com/t5/Vivado-TCL-Community/BITSTREAM-properties-in-script-when-where-to-set/td-p/703203
For this problem, if the interface is selected as SPIx1, there won't be any problem generating the image. But the bandwidth will be 8 bit?
Q2. I continue with SPIX1 and "load data files" to add my partial reconfiguration bitstream.
According to Page 65 in:
https://www.xilinx.com/support/documentation/ip_documentation/prc/v1_0/pg193-partial-reconfiguration-controller.pdf#page=65&zoom=100,0,92
I should make corresponding bin file first and load it. However, I select bit file for reconfiguration bitstream and it processed.
Is this okay?
Q3. I can't find the SPI Flash part MT25QU512ABB8ESF for ZCU102, which is stated in its user guide.
Can anyone advise me regarding the two questions above?
-Thanks
Re: ZCU102 Quad-SPI flash partial reconfiguration image question
You need to follow the zynq Mpsoc tutorial. Steps which you have listed above are for 7 series, Kintex, Virtex not for zynq or zynq mpsoc.
Refer to this hands on user guide and create the project and try to boot from qspi.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_1/ug1209-embedded-design-tutorial.pdf
Zynq TRM https://www.xilinx.com/support/documentation/user_guides/ug1085-zynq-ultrascale-trm.pdf
Harshit
