Observer tinghao780609
I want to programe the bitstream in FPGA(my board is ZCU106).
but I got this errror message
ERROR: [Labtools 27-3303] Incorrect bitstream assigned to device. Bitstream was generated for part xczu7ev-ffvc1156-2-e, target device (with IDCODE revision 0) is compatible with es2 revision bitstreams.
To allow the bitstream to be programmed to the device, use "set_param xicom.use_bitstream_version_check false" tcl command.
ERROR: [Labtools 27-3165] End of startup status: LOW
ERROR: [Common 17-39] 'program_hw_devices' failed due to earlier errors.
So in acording this message I install the ES verison in vivado,but I can't find that the xczu7ev-ffvc1156 has ES2 verison.
What should I do?
Re: ZCU106
Copy and paste the "set_param" command up to and including the "false" to your tcl command line on Vivado
See if that works
Ebrahim
Re: ZCU106
See if that works
Ebrahim
Re: ZCU106
Hi ebrahimm
It seem to work, thanks for your help.
