bfung_2
Zynq 7020 PUDC_B floating?
I'm planning IO for a custom board and I'd like to use BANK 13 with LVCMOS25 logic level IOs.
I need to figure out what to do with the PUDC_B IO in Bank 34 (which I'm not powering as I'm not using this bank at all).
I take it without powering on Bank 34 that the IOs are useless. What are the consequences of leaving PUDC_B floating? What alternatives are there to either tie this pin high or low without powering on Bank 34?
Tags (3)
ddn
Hi @bfung_2 ,
Please refer this AR#59958 which describes what happens if PUDC pin is left floating.
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
ddn
Hi @bfung_2 ,
Deepak D N
