configure FPGA from micro sd card in the kcu105 board
In the user mannual said we can onfiguration FPGA from micro SD card .But I can not find the techincal referece design.I find it need at least two file xlinx.sys and config.def.In addition to these two files are the required BIT files.can you give me the file about Configuration FPGA from micro SD card in the kcu105 board.I have an empty sd-card .can you teal me how to configure it.
Re: configure FPGA from micro sd card in the kcu105 board
Hello @xiangyi321
I have provided a link to UG917, the KCU105 Board User Guide, which goes over how to configure the device using a micro-sd card. The "FPGA Configuration" section starts on page 14 of the user guide. I hope this helps!
UG917: https://www.xilinx.com/support/documentation/boards_and_kits/kcu105/ug917-kcu105-eval-bd.pdf
