error cse -'1':errors encountered while programming the device impact
    Am seeing an pop up issue as "" error cse -'1':errors encountered while programming the device in iMpact   ""
(Program not successful and done is not going to High).
Pleas help me in this error so it will be helpful to complete my work asap.
SaiParveen
OK for this error, I remember two possible reasons:
1. The tool did not work stablely. Try with a 14.2 iMPACT if possible.
2. Check the mode pins on board. Make sure they are with proper pullup/downs and set to stable values during Configuration.
You need to provide more details about your device, usage and operation procedure. This could be due to a tool bug or incorrect operation. You can search the Xilinx.com first by the error content and you can see several articles. Check if you encounter one of them.
 I am using an Virtex7 and Flashing it by using Impact 64bit software on Win10 PC, for programming i am using an Xilinx USB Programmer
I have total 6 boards out off that 1 board has this programming issue.
While programming am seeing that 8% is programable and gaves an pop up windows like " error cse -'1':errors encountered while programming the device "
And in Console am seeing thsi error:
'1':Configuration data download to FPGA Not successful: DONE did not go high
Please help me in this regarding.
Sai
I have total 8 boards out of which 3 have the same issues not able to program the xc7V2000T FLASH using Impact 64bit 14.6 tool with Win10 System.
Even getting the similar issue with Win7 also.
Its flalshing for 8% then suddenly stops nd gave an error on pop window as "error cse -'1':errors encountered while programming the device in xilinx"
After program failed ,on Console seeing the below message:::
Reset Core
Using x16 mode ...
Set Data Width
'1': Erasing device...
done.
'1': Erasure completed successfully.
Reset Core
Using x16 mode ...
Set Data Width
INFO:Cse - Using Buffered Programming.
'1': Programming Flash.
INFO:Cse - Core Status Register: [80] : 0
INFO:Cse - Core Status Register: [81] : 0
INFO:Cse - Core Status Register: [82] : 0
INFO:Cse - Core Status Register: [83] : 0
INFO:Cse - Core Status Register: [84] : 1
INFO:Cse - Core Status Register: [85] : 0
INFO:Cse - Core Status Register: [86] : 0
INFO:Cse - Core Status Register: [87] : 1
INFO:Cse - Core Status Register: [88] : 1
INFO:Cse - Core Status Register: [89] : 0
INFO:Cse - Core Status Register: [90] : 0
INFO:Cse - Core Status Register: [91] : 0
INFO:Cse - Core Status Register: [92] : 0
INFO:Cse - Core Status Register: [93] : 0
INFO:Cse - Core Status Register: [94] : 0
INFO:Cse - Core Status Register: [95] : 0
'1': Errors encountered while loading microprogram.
ERROR:Cse - '1': Errors encountered while programming device.
Reset Core
PROGRESS_END - End Operation.
Elapsed time = 412 sec.
'1': Configuration data download to FPGA was not successful. DONE did not go high, please check your configuration setup and mode settings.
SaiPraveen
Thanks for your support.
I tried with Impact 14.2 its able to Flah it.
