getting WARNING:iMPACT:923 - Can not find cable, check cable setup !
I am using ISE 14.7, i am not able to program my device as i am receiving  following message...
INFO:iMPACT - Digilent Plugin: Plugin Version: 2.4.4
INFO:iMPACT - Digilent Plugin: no JTAG device was found.
AutoDetecting cable. Please wait.
*** WARNING ***: When port is set to auto detect mode, cable speed is set to default 6 MHz regardless of explicit arguments supplied for setting the baud rates
PROGRESS_START - Starting Operation.
Connecting to cable (Usb Port - USB21).
Checking cable driver.
Driver file xusbdfwu.sys found.
Driver version: src=1027, dest=1027.
Driver windrvr6.sys version = 11.7.0.0. WinDriver v11.7.0 Jungo Connectivity (c) 1997 - 2014 Build Date: Oct 26 2014 X86 32bit SYS 09:05:06, version = 1170.
Invalid device driver license.
Cable connection failed.
Connecting to cable (Parallel Port - LPT1).
Connecting to cable (Parallel Port - LPT2).
Connecting to cable (Parallel Port - LPT3).
Connecting to cable (Parallel Port - LPT4).
PROGRESS_END - End Operation.
Elapsed time = 1 sec.
Cable autodetection failed.
Re: getting WARNING:iMPACT:923 - Can not find cable, check cable setup !
Which OS you are using? Can you follow the below steps:
https://forums.xilinx.com/t5/Design-and-Debug-Techniques-Blog/Manually-installing-Cable-Drivers-for-Xilinx-Platform-Cable-USB/ba-p/992593
