younes-123
how to connect and configure many fpga
Hi team,
 I have 4 fpga artix7 witch communicate with each others .I exange bit beteween FPGA . 2 fpga has the seem code vhdl and one  fpga is different and the last fpga ( has the seem code but one port less).  I use one port inout to connect each 2 fpga .
So ,I have  4 FPGA with different bitstream( probably 3 are the seem) and witch communicate with each others . I must use  Daisy Chain Configuration(Serial)?
So  for simulation can i use only behavioral simulation or post_synthese simulation?
With Regards,
iguo
Can I know what the question is? You are asking about how to configure these FPGAs?
If so you can connect them in serial daisy chain or jtag daisy chain, or you can program them individually. Either is OK. Configuration method has no relationship with the content you are going to program into.
