Voyager
Voyager
how to switch between different bit file in multi mode qspi on vcu118
Hi Friends,
Am using VCU118 and Vivado 2019.2.
i loaded 2 bit files in the QSPI. i want to work on one bit file for some time and then on other.
how to boot these whenever i want ?
Any help or suggestions are highly appreciated.
-Sampath
-Sampath
Hi @ssampath ,
Use Multiboot concept by referring this XAPP1257.
Use external trigger ( like push button) which acts as trigger, which is responsible for loading BIT Files (which you wish) from flash. To achieve use this you need to use ICAP Primitive.
For example : Initially 1st Bit File will load from Nth address of flash to FPGA. And you continue to use that for a while and then when you again press External Pushbutton present on board, it will load another Bit File.
Refer ML605 multiboot steps  and Design files which uses above method.
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
