06-06-2020 01:45 AM
i want to boot Ubuntu Desktop on ZCU106, so i tryed and follow this site
but i get this problem...
Xilinx Zynq MP First Stage Boot Loader
Release 2019.1 Jun 10 2019 - 09:24:58
and not work after this scene
06-08-2020 03:37 PM
I'm having the same problem!
06-08-2020 03:45 PM - edited 06-08-2020 03:50 PM
Hi @Kuin and @mohammedalasmar
What kind of device are you using as boot storage ?
If SD card, would you share this information.
Also, would you share information for BOOT.bin by file command and FIT image (image.ub) by mkimage or dumpimage command ?
Best regards,
06-09-2020 09:18 AM - edited 06-09-2020 09:20 AM
I'm using the Ready_to_test_image ZCU106_UbuntuDesktop_2019_1.img (link below)
I've added this image to an SD card (32G class 10) using 'dd' command as mentioned in this link
Many thanks
06-09-2020 03:10 PM - edited 06-09-2020 03:11 PM
It might be related with the following URL.
Would you make sure it ?
https://www.xilinx.com/support/answers/72113.html
BTW, did you already make sure boot mode at SW ?
Best regards,
10-06-2020 11:30 PM
I'm having the exact same problem with my ZCU106 board and Ubuntu release. I'm also using same ubuntu release 2019.1 file. Pre built is not successfully loading into board and source file is also giving multiple error when importing into vivado design suite using .tcl as instructed in the link.
Now My questions are:
1)How to run Pre Built image provided in above link on ZCU106?
2)Why bit file is not used while packaging BOOT.BIN file in above link?
3)Can I use vivado on windows to generate HDF file? I'm using vivado on windows but I can't built this project successfully by following instruction given in above link.
Also please help since I'm stuck on this issue for more then a month. Instructions are simple but there is no proper solution for those problems.
