iMPACT & Vivado Driver Issues
My system, which is Windows 7, needs to be able to use both iMPACT and Vivado 2018. However, I found that there are incompatible Windows Jungo Connectivity drivers. Vivado uses a version 11 windrv6.sys (which is jungo) and iMPACT uses a version 10.
I currently have the version 11 driver and iMPACT will not detect the USB correctly stating to check our cable setup.
Is there a compromise so that I can get both software to work on the same windows 7 PC?
Hi @Brian_T
Are you unable to find the cable and the Jungo drivers? This may be related to the issue that you are seeing since the solution also resolves issues with Windows 7 PC  AR 44397
Hi @Brian_T,
For Windows 7 both iMPACT and Vivado should use Jungo version 10.2.1 and not 11.
Please see the following blog:
https://forums.xilinx.com/t5/Design-and-Debug-Techniques-Blog/Manually-installing-Cable-Drivers-for-Xilinx-Platform-Cable-USB/ba-p/992593
Do you see any error messages?
When you check the Jungo version are you seeing v 11 installed? If so, you should uninstall and reintall version 10.2.1.
Wendy
Xilinx Technical Support
