iMPACT error
I am trying to program XC95288XL CPLD.  I have already generated the .jed file from my VHDL code. I've also tried to reinstall Platform cable drives and Green status light is on.
I am using ISE14.7
Getting the following error:
INFO:iMPACT - Current time: 2018-09-06 12:27:54 PM
INFO:iMPACT:583 - '1': The idcode read from the device does not match the idcode in the bsdl File.
INFO:iMPACT:1578 - '1':  Device IDCODE :        00001111111111111111111111111110
INFO:iMPACT:1579 - '1': Expected IDCODE:    00001001011000010110000010010011
PROGRESS_END - End Operation.
Elapsed time =      0 sec.
I have tried to replace CPLD and getting same error. I cannot erase/program the cpld.
Please advice what should I do.
Best regards
Re: iMPACT error
Hello Vastal,
Please follow the Xilinx AR#13529 for the error you are facing.
Thanks and Regards,
Deepak D N
Please don't forget to give Kudos or Mark it as an Accepted Solution
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
Re: iMPACT error
Already Tried this steps as well as reinstalling cable drivers same error every time.
Re: iMPACT error
Hi @vatsal.naik
You can try following procedure for Platform cable USB II to work under Windows 10 environment:
1. Connect cable to PC/Laptop.
2. In device manager if cable is detected then uninstall and delete driver of cable.
3. Now after connecting cable, it should show unidentified device.
4. Remove platform USB cable
5. Navigate to "C:\Xilinx\14.7\ISE_DS\common\bin\nt64" for 64-bit installs or "C:\Xilinx\14.7\ISE_DS\common\bin\\nt" on 32-bit installs.(using Command Prompt in administrator mode)
6. Run wdreg -compat -inf %cd%\windrvr6.inf uninstall
7. Run wdreg -compat -inf %cd%\windrvr6.inf install
8. Connect the Xilinx USB cable.
Also take look at https://www.xilinx.com/support/answers/44397.html and https://www.xilinx.com/support/answers/54381.html
If does not work please share snapshot of device driver after connecting cable to Laptop/PC.
Provide OS and Impact version details.
Bhushan
Bhushan
Re: iMPACT error
Hi @bpatil
I have tried this solution, but didn't work. I can see the green status light on platform cable II is on so i think it is connected with proper driver.
I am using Windows10 64-bit OS  & iMPACT 14.7(nt64). Also, I have tried replacing cpld it didn't work.
Please have a look at  attached screenshots.
  1. Device Manager
  2. Impact Device Added
  3. Error Message
Let me know if you need anything else.
Thanks!
Re: iMPACT error
Hi @vatsal.naik
1. Try reducing JTAG frequency and try configuration. It will clarify, there is any problems due to signal integrity.
2. Check power rails are at recommended level or not (while configuration)
3. Currently, which programming cable you are using for configuration?
4. Try changing programming cable and try configuration
5. From which vendor you have purchased CPLD?
6. Provide snapshot of CPLD device on board
7. If possible share configuration schematic of your board.
Bhushan
Bhushan
Re: iMPACT error
Hi @bpatil, Thank you for the reply,
  1. I have already tried that but same error.
  2. Power rails are ok, already tested it.
  3. Xilinx Platform Cable II.
  4. I also think this error is because programming cable, I have ordered Digilint XUP USB-JTAG programming cable ( Which           Support 9500XL cpld ) from Digikey, and will try reprogramming once I receive it.
  5. Digikey.ca
I think the programming cable is faulty, and I will wait for the new programming cable and try reprogramming again probably the early week. If that doesn't work I will send you design schematics. Thank you!
Best Regards
Re: iMPACT error
Hello @vatsal.naik,
Please go through the forum post:
https://forums.xilinx.com/t5/Virtex-Family-FPGAs/error-iMPACT-583-1-idcode-mismatch-between-bsdl-file-and-read/td-p/18699
Hope you will get some inputs.
Naveen
Re: iMPACT error
Hi @nmanitri,
Thanks for the information. In the post, the problem was solved by pull-up resistors, and it is required for Coolrunner-II cpld.
I am using XC9500XL cpld and  According to this document,
https://www.xilinx.com/support/documentation/application_notes/xapp501.pdf
cpld already has internal pull-up for TDI and TMS Jtag pins, Do we still need external pull-up resistors? Thank you!
Best Regards
Re: iMPACT error
Hi @vatsal.naik
Check UG445 (v1.2) Page 12
I hope this clarifies your query.
Bhushan
Bhushan
Re: iMPACT error
Hello @vatsal.naik,
Agree with @bpatil if it not work. Please check  XAPP501 on page 9.
Hope this will help you.
Naveen
Re: iMPACT error
Hi @bpatil @nmanitri
I will try with external pull up resistor of 4.7KOhms. XAPP501 really confused me, On page 9. It says that for XC9500XL already have internal pull-ups and doesn't require any external pull-ups since pins are dedicated for JTAG use only.
Best Regards
Re: iMPACT error
Hello @vatsal.naik,
Did you check TCK frequency?
The JTAG Clock for the XC9500/XL devices, TCK, has a maximum frequency of 10 MHz.
I suggest you please check TCK clock frequency. Depending on what you find you may be able to fix the signal integrity problem with the capacitor or a resistor.
Naveen
Re: iMPACT error
Hi @vatsal.naik,
I hope this clears your confusion regarding external pull up resistor. Since XC9500XL devices have internal pull up there is no need of connecting external pull up.
Please check all the power rails are noise free and are within the range. I hope you went through AR#13529. And please go through general JTAG check list from above image.
Deepak D N
Please Reply or Give Kudos or Mark it as an Accepted Solution.
Deepak D N
Re: iMPACT error
@Hi @ddn,
That is what I said earlier, that I'm using XC9500XL cpld, so there won't be any need for external pull-up resistors for JTAG.
Thanks!
Re: iMPACT error
Update,
The problem has been solved by replacing programming cable.
I am not sure why but windows always detected the platform cable, and the status light on platform cable was also responding correctly. Just was not able to program with it.
Thank you all, Appreciate your help!
