jpathiku
is VCCO_65 essential for Ultrascale+ in Slave Serial Mode
i am using slave serial configuration mode for a Virtex Ultrascale+ FPGA. the documentation says that the DOUT pin uses VCCO_65. the DOUT pin is unused in our design.
is VCCO_65 essential for the configuration process to work? can i leave the VCCO_65 unconnected?
regards,
joseph
kkn
if you are not using dout i.e daisy chain configuration mode then Bank65 is not used for slave serial configuration.
Check table 1-11/1-12 in ug570 for bank voltages requirment
http://www.xilinx.com/support/documentation/user_guides/ug570-ultrascale-configuration.pdf
kkn
jpathiku
