kintex7 BPI flash programming failed
 I am custom kintex 7 (xc7k325t-2) with micron 1gb NOR Flash (MT28EW01GABA1HPC-0SIT) as programmable memory. The programming of NOR Flash fails with the following message
INFO: [Labtools 27-3164] End of startup status: HIGH
program_hw_cfgmem -hw_cfgmem [get_property PROGRAM.HW_CFGMEM [lindex [get_hw_devices] 0 ]]
Mfg ID : 0 Memory Type : 0 Memory Capacity : 0 Device ID 1 : 0 Device ID 2 : 0
Performing Erase Operation...
Erase Operation failed.
ERROR: [Labtools 27-3161] Flash Programming Unsuccessful
ERROR: [Common 17-39] 'program_hw_cfgmem' failed due to earlier errors.
The INIT_B signal is low after power up and does not gets asserted.
The configuration register after programming  failed is shown below
REGISTER.CONFIG_STATUS 01000010000100000000101011111100
REGISTER.CONFIG_STATUS.BIT00_CRC_ERROR 0
REGISTER.CONFIG_STATUS.BIT01_DECRYPTOR_ENABLE 0
REGISTER.CONFIG_STATUS.BIT02_PLL_LOCK_STATUS 1
REGISTER.CONFIG_STATUS.BIT03_DCI_MATCH_STATUS 1
REGISTER.CONFIG_STATUS.BIT04_END_OF_STARTUP_(EOS)_STATUS 1
REGISTER.CONFIG_STATUS.BIT05_GTS_CFG_B_STATUS 1
REGISTER.CONFIG_STATUS.BIT06_GWE_STATUS 1
REGISTER.CONFIG_STATUS.BIT07_GHIGH_STATUS 1
REGISTER.CONFIG_STATUS.BIT08_MODE_PIN_M[0] 0
REGISTER.CONFIG_STATUS.BIT09_MODE_PIN_M[1] 1
REGISTER.CONFIG_STATUS.BIT10_MODE_PIN_M[2] 0
REGISTER.CONFIG_STATUS.BIT11_INIT_B_INTERNAL_SIGNAL_STATUS 1
REGISTER.CONFIG_STATUS.BIT12_INIT_B_PIN 0
REGISTER.CONFIG_STATUS.BIT13_DONE_INTERNAL_SIGNAL_STATUS 0
REGISTER.CONFIG_STATUS.BIT14_DONE_PIN 0
REGISTER.CONFIG_STATUS.BIT15_IDCODE_ERROR 0
REGISTER.CONFIG_STATUS.BIT16_SECURITY_ERROR 0
REGISTER.CONFIG_STATUS.BIT17_SYSTEM_MONITOR_OVER-TEMP_ALARM_STATUS 0
REGISTER.CONFIG_STATUS.BIT18_CFG_STARTUP_STATE_MACHINE_PHASE 100
REGISTER.CONFIG_STATUS.BIT21_RESERVED 0000
REGISTER.CONFIG_STATUS.BIT25_CFG_BUS_WIDTH_DETECTION 01
REGISTER.CONFIG_STATUS.BIT27_HMAC_ERROR 0
REGISTER.CONFIG_STATUS.BIT28_PUDC_B_PIN 0
REGISTER.CONFIG_STATUS.BIT29_BAD_PACKET_ERROR 0
REGISTER.CONFIG_STATUS.BIT30_CFGBVS_PIN 1
REGISTER.CONFIG_STATUS.BIT31_RESERVED 0
INIT_B pin on the custom board is grounded or has connection issues. Check it.
Hi iguo
 The init_b pin is connected to a dual led.I am attaching a snapshot the connection below.BPI configuration.JPG
Once the LED is lighted, resistance of the Emitter becomes zero and it pulls INIT_B down to ground. Saw tons of wrong designs of this.
HI iguo
I just received a another board with same configuration in which flash programming works fine. I will remove the Led as per your advice and will let u know  if i am still facing any issues.
Hi iguo
Tried programming the flash after removing the Led but programming gets failed at verify stage.I am able to program the flash without the verify option but upon power cycle the changes are not reflected on the hardware.I am able to erase the flash and no errors during blank check operation.This is the error i get when i try to program the flash with program and verify option selected.
Mfg ID : 89 Memory Type : 227e Memory Capacity : 0 Device ID 1 : 2228 Device ID 2 : 2201
Erase Operation successful.
Performing Program and Verify Operations...
Program/Verify Operation failed.
Byte 0 does not match (00 != FF)
ERROR: [Labtools 27-3144] Invalid option: Byte 0 does not match (00 != FF)
program_hw_cfgmem: Time (s): cpu = 00:00:03 ; elapsed = 00:00:14 . Memory (MB): peak = 932.367 ; gain = 3.930
The configuration registers after programming is shown below
register status
boot status
REGISTER.BOOT_STATUS 00000000000000000000000000000001
REGISTER.BOOT_STATUS.BIT00_0_STATUS_VALID 1
REGISTER.BOOT_STATUS.BIT01_0_FALLBACK 0
REGISTER.BOOT_STATUS.BIT02_0_INTERNAL_PROG 0
REGISTER.BOOT_STATUS.BIT03_0_WATCHDOG_TIMEOUT_ERROR 0
REGISTER.BOOT_STATUS.BIT04_0_ID_ERROR 0
REGISTER.BOOT_STATUS.BIT05_0_CRC_ERROR 0
REGISTER.BOOT_STATUS.BIT06_0_WRAP_ERROR 0
REGISTER.BOOT_STATUS.BIT07_0_SECURITY_ERROR 0
REGISTER.BOOT_STATUS.BIT08_1_STATUS_VALID 0
REGISTER.BOOT_STATUS.BIT09_1_FALLBACK 0
REGISTER.BOOT_STATUS.BIT10_1_INTERNAL_PROG 0
REGISTER.BOOT_STATUS.BIT11_1_WATCHDOG_TIMEOUT_ERROR 0
REGISTER.BOOT_STATUS.BIT12_1_ID_ERROR 0
REGISTER.BOOT_STATUS.BIT13_1_CRC_ERROR 0
REGISTER.BOOT_STATUS.BIT14_1_WRAP_ERROR 0
REGISTER.BOOT_STATUS.BIT15_1_SECURITY_ERROR 0
REGISTER.BOOT_STATUS.BIT16_RESERVED 0000000000000000
REGISTER.CONFIG_STATUS 01000010000100000001101011111100
REGISTER.CONFIG_STATUS.BIT12_INIT_B_PIN 1
NOTE : I am using vivado 2016.4 to program the device.
