duanev
linux centos Unable to detect JTAG cable
After working correctly for a while
# program_flash -jtagtargets
began failing with "Unable to detect JTAG cable".  Problem was finally found: digilent-adept2* files in /tmp apparently did not get cleaned up properly:
# rm /tmp/digilent-adept2*
fixed the problem.
hj
Thanks for sharing the details.
For more information please refer to configuration resources https://forums.xilinx.com/t5/FPGA-Configuration/Configuration-Resources/m-p/753763/highlight/true#M5891
duanev
There doesn't appear to be a way to "Accept as Solution" on the first post.
