mcs-86 parsing source code
I want to program *.mcs file (Intel mcs86 format) to a serial flash (Configuration memory for FPGA) with SPI interface
My aim is to implement "Quickboot/multiboot" scheme in serial flash ....
1. We have control over SPI and we can perform read write to SPI flash...
2. How to parse *.mcs file before writing to SPI flash??... does Xilinx provide any source code/example code to parse *.mcs so that proper data could be written on to memory...
Advisor
Advisor
Check this answer record; it seems to have everything you need.
In reality i have 2 different requirements....one for quickboot and other for multiboot.....
1. Quick boot
In this case as I should be communicating to ""SpiFlashProgrammer.vhd"" port to program bit file ie
1. i need to parse input *.mcs
2. fetch data to ""inData32"" port of ""SpiFlashProgrammer.vhd""
3. ""SpiFlashProgrammer.vhd""  would handle erase  flash memory , erase critical word,verification  and handle quick boot header....
So as I understand I need to parse *.mcs data field and relay it to ""inData32"" port of ""SpiFlashProgrammer.vhd""??.....I have to discard the address filed in *.mcs
if not please advice....
2. Multiboot
In this case erasure has to handled by the user program
User has to feed in  address and data from *.mcs to serial flash....What is the role of *.prm file??
Does xilinx provide any example code or source code for this purpose ??
i'm doing xapp1081 as well. i think your idea is correct, at least it's same as mine... Did you have any progress? it seems i can't feed the programmer with the right update data contents. Refers to your question in "1. Quick boot" , i converted *_update.mcs to .bin and tried to feed to inData32.
looking forward your reply,
Nick
Hi there,
i'm really excited that after all everything goes pretty beautiful and i see that bling LED! For whom might encounter the same situation, i used N25Q256, SPI *1 with bit compression.
cheers,
Nick
Can you share how you parse the mcs file into the FPGA? Did you just use .bin file for parse?
I am trying to parse the file into ethernet frame, Any idea how to do that?
Also, the flash memory I am using is spansion s25fl128, does the quickboot module able to handle it?
thanks!
