nkz file
in  ug908 an nkz is described as follows :
" Because you are advised to program eFUSE settings in multiple passes, eFUSE settings are
always exported to an externally visible NKZ file, which is updated during each eFUSE operation.
it isw also written the the *nkz file can make the process of "
mass-program the same eFUSE settings into many devices "
could you pls explain who to use the *.nkz file during mass-program ?
and give an example of the use .
thanks
David Geron
Elisra
