Visitor eleni_palla
partial reconfiguration with encrypted partial bitstream
Hello all,
I was wondering if it is possible to do a partial reconfiguration design where the partial bitstream is encrypted and the static design is not. We need to deliver a encrypted bitstream to a client who will then load it in a existing design on a virtex 7. The client would have the encryption key already programmed in bbram and we will make subsequent deliveries of partial bitstreams.
I am following the ug947 tutorial but I cannot figure out at which point we need to provide the property:
set_property BITSTREAM.ENCRYPTION.ENCRYPT Yes [current_design] -> here ideally I would like to have the reconfigurable partition. Is there a way to do that?
Eleni
Re: partial reconfiguration with encrypted partial bitstream
@eleni_palla,
This scenario is not supported by any current Xilinx FPGA.  In order for a partial bitstream to be encrypted with an AES key stored in BBRAM or eFUSE, the initial configuration must also be encrypted with the same key.  The opposite is supported (encrypted full then unencrypted partial) when loading over ICAP.  But the only solution for your scenario is to insert your own decryption engine in static that would decrypt the partials before delivering them to the configuration engine.
thanks,
david.
@eleni_palla,
thanks,
david.
