possible method of programming eFUSE key internally
Is it possible to store the AES decryption key in eFUSE using a design mapped onto the FPGA?
I know that one can reprogram the FPGA through the ICAP. Using this access, could we also
have some mechanism to store the key onto the eFUSE? Information about any possible alternative would be helpful.
Which device family?
On UltraScale & UltraScale+, you can do this internally via MASTER_JTAG.
see here for details
http://www.xilinx.com/support/documentation/application_notes/xapp1283-internalprogramming-bbram-efuses.pdf
On previous families, you can do it from the FPGA (e.g. MicroBlaze or statemachine) but would need an external connection (e.g. board-level) back to the JTAG pins - which may not be ideal for a variety of reasons you might imagine.
Thanks for your reply @barriet. This is helpful. There is no particular family that I am looking at currenctly.
Yes, I am trying to avoid this external communication because this provides an opportunity for probing.
Do you think this feature will be available on futrure FPGA families?
Thank you again.
Have physical access (the external PL->JTAG) to this loopback connection may not be a problem when the e-fuses are programmed in a secure area and there are other system level protections for fielded systems.
But we added the internal method to address some concerns here - you can do this now on US/US+ via the app note I mentioned.
For US/US+, we also have this which is likely the best place to start for security considerations:
https://www.xilinx.com/support/documentation/application_notes/xapp1098-tamper-resist-designs.pdf
and
http://www.xilinx.com/support/documentation/application_notes/xapp1267-encryp-efuse-program.pdf
for 7 series:
http://www.xilinx.com/support/documentation/application_notes/xapp1084_tamp_resist_dsgns.pdf
and
http://www.xilinx.com/support/documentation/application_notes/xapp1239-fpga-bitstream-encryption.pdf
and for ZU+ MPSoC:
http://www.xilinx.com/support/documentation/application_notes/xapp1323-zynq-usp-tamper-resistant-designs.pdf
http://www.xilinx.com/support/documentation/application_notes/xapp1320-isolation-methods.pdf
http://www.xilinx.com/support/documentation/application_notes/xapp1319-zynq-usp-prog-nvm.pdf
Lots of good resources here for security... ;)
Good luck.
@barriet wrote:
Have physical access (the external PL->JTAG) to this loopback connection may not be a problem when the e-fuses are programmed in a secure area and there are other system level protections for fielded.
If the FPGA is being programmed in an untrusted facility, what system level protection could be leveraged to secure the use of external JTAG for eFUSE programming?
Thanks for the resources.
Hi @barriet
it is mentioned in the XAPP1283 the internal programmability gives the opportunity to send the eFUSE key in encrypted form. (please see the snippet). Now where the decryption key of the eFUSE key would come from? Would that be initially transferred to the FPGA through the "secure key exchange function"? I believe it would be a custom protocol developed by the users themselves? Just wanted to make sure I understood.
