Sugi
"Revision No" of XAZU5EV-1SFVC784Q
Let me know, what is the latest product revision No of XAZU5EV-1SFVC784Q just now?
iguo
I can answer part of the question, yes the 4 most significant bits of IDCODE stands for the silicon revision of a chip, this is true for each Xilinx device. IDcode is not only the chip revision, the other part of it tells famlily, device and manufactor info.
The silicon revision info is not public. If you do have such a need, please contact Sales or FAE, they could ping the Quality team to get this.
vatsalt
The latest available version is rev 1.1( pic ). You can refer the below link for more details on the part.(XAZU5EV and XCZU5EV are footprint compatible refer UG 1075 pg.114 ).
https://www.xilinx.com/support/packagefiles/zuppackages/xczu5evsfvc784pkg.txt
Best Regards,
Vatsal
Sugi
Hi Vatsalt.
Thank you for your reply.
I'd like to ask you more question.
I want to check the latest "chip revision" of XAZU5EV1SF VC784Q.
Q1)Could you tell me the "Silicon Chip Revision" of XAZU5EV1SF VC784Q?
P.S:
See the document below.
https://www.xilinx.com/support/documentation/errata/en285.pdf
Please see table1 on Page2.
I think that the Silicon Chip revision is "ID code [31:28]".
Q2)Is "ID code" the Chip Revision ?
Could you answer me my questions.
Beast Regards
S.Sugi.
iguo
Sugi
Hi Iguo.
OK, I'll contact the Xilinx sals about that. So I ask about it.
Thank you.
Best Regards
S.Sugi.
