MuzamilFarid
slave_reg_multiple drivers
Hello everyone
i am encountering a problem related to multiple driver pins, i have a counter running in my module which i instantiate in another module where Slave peripheral is implemented with 4 slave registers.when i connect my counter(slv_signal) to the slave register 1, i see red lines in simulation. slv_reg1 is assigned in another process but that process does not run because enable signal of that process is always zero.
florentw
HI @MuzamilFarid
You cannot assign the same signal in multiple processes.
Just use different signals in each process and assign the final signal outside the process
<output> <= <signal1> WHEN <selector> ='1' ELSE<signal2>;
Florent
florentw
HI @MuzamilFarid
Florent
MuzamilFarid
@florentw
thanks for the suggestion
