Visitor adnan_awan1
spartan 3E usb-jtag progmming problem
Dear all I am using spartan 3E XC3s500E FG320 FPGA board and i am using impact for programming in boundary scan option after clicking initialization chain board successfully identified then i assigned new configuration file after that i click program xc3s500e but it stuck and following window open
Scholar austin
Re: spartan 3E usb-jtag progmming problem
What OS?
Note that running ISE is not supported on newer versions of Windows ....
What are the warnings, errors (if any)?
Austin Lesea
Principal Engineer
Xilinx San Jose
Visitor adnan_awan1
I am using window 7 ultimate
here is my code
when i click abort it shows
"write cmdbuffer failed 2000000f" in console window
Scholar austin
Windows 7 Pro 32/64-bit is only supported,
Although it does not look like a OS issue.
rst is missing from the sensitivity list (it is asynchronous to the clk the way it is written)
https://stackoverflow.com/questions/8991223/when-must-a-signal-be-inserted-into-the-sensitivity-list-of-a-process
Austin Lesea
Principal Engineer
Xilinx San Jose
