the error when connceting to the VCU118 board
The version of the Vivado is 2019.2, the board is VCU118, when I conncet the boad with usb cable, the error is:
Error during cs_server initialization: Failed to connect cs_server at TCP:localhost:3042 to hw_server at TCP:localhost:3121.
some days ago, I could connect the board, but after I install the software ISE 14.7 for  win10, today I connect the board, I meet the error!
How can I solve the problem?
Many thanks!
Re: the error when connceting to the VCU118 board
Can you try to use below command
set_param labtools.enable_cs_server false
Also disable the anti-virus if there is any. See it works.
-Harshit
-Harshit
