Visitor sandeepcrl
vivado 2017.1 BPI Flash programming error
I am using PC28F128P33B Flash with Artix 7 devices. I am getting unable to query common flash interface error.
Support for this BPI flash for Artix 7 devices was not there till Vivado 2016.1.
Does Viado 2017.1 supports PC28F128P33B Flash?
B Sandeep.
Re: vivado 2017.1 BPI Flash programming error
Hi @sandeepcrl,
Yes, PC28F128P33B is supported in Vivado 2017.1.
Please refer page318 of UG908.
Deepak D N
Please reply or give kudo or mark it as an Accepted Solution.
Visitor sandeepcrl
I am getting unable to query common flash interface error while programming flash from Artix 7.
can you provide the complete vivado programmer log file for the issue you are facing.
can you recheck your BPI interface signals are proper by referring to UG470 for the bpi configuration section
Hi @sandeepcrl,
Please share the complete error log file.
The Indirect programming core sends a CFI query to the flash before carrying out any info. You will see this message when this fails. Try the following -
Reduce cable speed(Try reducing it to 3MHz or lower)
Check schematic connections
Check Flash is powered correctly
These are common causes of this issue.
Deepak D N
Please reply or Give kudo or Mark it as an Accepted Solution.
Visitor sandeepcrl
Mfg ID : 0 Memory Type : 0 Memory Capacity : 0 Device ID 1 : 0 Device ID 2 : 0
Performing Erase Operation...
Erase Operation failed.
ERROR: [Labtools 27-3161] Flash Programming Unsuccessful
ERROR: [Common 17-39] 'program_hw_cfgmem' failed due to earlier errors.
Reduced cable speed didn't help.
Schematic connections are ok.
Power supply to the Flash is stable.
