w_en_b_cntl efuse cntl bit (5) not available in GUI Vivado 2018.2
I have seen other configuration questions about the eFUSE bits that show bit(5) in the GUI window yet I don't have it available in 2018.2 for a V7 design.  Is this a known issue?  How do I set this bit and lock down my eFUSE settings?
I was provided an answer to this elsewhere and wanted to share so the issue could be closed.
Because of a problem with earlier versions, the w_en_b_cntl bit was removed from the GUI list, and must be set with a TCL command:
program_hw_devices -control_efuse {20} [lindex [get_hw_devices] 0]
Although it does not appear to be updated in the Xilinx documentation there are help files in Vivado that provide this tcl command.
