gerstn
ABEL TO VHDL
hello,
how can I write ABEL Code like this:
BR.clk = CK;    // BR is a node register CK is a input pin
BR.ar = RSN;  // RSN is a input pin
in VHDL.
Thanks for your help
gszakacs
Professor
Professor
Not quite.  The D input part of the equation needs to be inside the process
block in order to happen at the clock edge.  In Abel you just use the := to
indicate at the clock edge.  In VHDL the assignment needs to take place
inside the elsif ...
Like:
process (CK, RSN)
begin
   if RSN='1' then
      BR <= '0';
   elsif (CK'event and CK ='1') then
       if BR(6) ='0' then BR <= BR+1;
       else BR<="0000000"; -- in VHDL width of constant has to match width of BR
   end if;
end process;
And:
process (BR(6), RSN)
begin
   if RSN='1' then
      UC <= '0';
   elsif (BR(6)'event and BR(6) ='1') then
      UC <= not UC;
   end if;
end process;
-- Gabor
gszakacs
Professor
Professor
You can find this in the language templates included in the ISE GUI.  What you're
describing in Abel is a flip-flop with an asynchronous clear input.  Normally you'd also
have an equation for the D input of your flip-flop.
-- Usage of Asynchronous resets may negatively impact FPGA resources
-- and timing. In general faster and smaller FPGA designs will
-- result from not using Asynchronous Resets. Please refer to
-- the Synthesis and Simulation Design Guide for more information.
process (<clock>, <reset>)
begin
   if <reset>='1' then
      <output> <= '0';
   elsif (<clock>'event and <clock>='1') then
      <output> <= <input>;
   end if;
end process;
In the above code, <output> could be replaced with BR,
<input> would be whatever goes to BR.d, <reset> could be RSN, and
<clock> would be CK.  Note that this code generates an active
high reset input.  RSN seems to imply an active low signal, but your
Abel code doesn't seem to bear this out.  The language templates
also have standard templates for flip-flops with asynchronous
presets and clock enables in all combinations of rising and falling
edge and active high or low inputs.
-- Gabor
gerstn
Hey thanks for your help!!
If I understand your description the following Abel Code:
when !BR6 then BR := BR +1
 else        BR := 0 ;
   BR.CLK = CK;
   BR.AR = RSN;
 UC := !UC;
   UC.CLK = BR6;
   UC.AR = RSN;
is the same as this in VHDL
elsif BR<='0';
process (CK, RSN)
begin
   if RSN='1' then
      BR <= '0';
      BR <= BR;
   end if;
end process;
gerstn
sorry I forgot
UC <= NOT UC;
begin
   if RSN='1' then
      UC <= '0';
      UC <= UC;
   end if;
end process;
thanks for your reply
gszakacs
Professor
Professor
Like:
process (CK, RSN)
begin
   if RSN='1' then
      BR <= '0';
   end if;
end process;
And:
begin
   if RSN='1' then
      UC <= '0';
      UC <= not UC;
   end if;
end process;
-- Gabor
gerstn
Ahh OK thanks a lot!!! Maybe I will have a question to my further work. Am I allowed to write you a pn if this happens ? :)
