AXI EthernetLite (LWIP): Write data From FPGA Board to PC Using Python Socket command
        Now i am able to print the data in Hercules, instead i need to print the data in Python Shell. I don`t know anything about Python eventhough i have tried but i am not able to do that. Please apologize me i have posting this query for second time.
Without using Hercules, how can i print my data into Shell.
I have attached all files even Python Code [But still data is printing in Hercules only]
TCP C Code (XSDK)
Main Function
#include <stdio.h>
#include "xparameters.h"
#include "netif/xadapter.h"
#include "platform.h"
#include "platform_config.h"
#if defined (__arm__) || defined(__aarch64__)
#include "xil_printf.h"
#endif
#include "lwip/tcp.h"
#include "xil_cache.h"
#if LWIP_DHCP==1
#include "lwip/dhcp.h"
#endif
/* defined by each RAW mode application */
void print_app_header();
int start_application();
int transfer_data();
void tcp_fasttmr(void);
void tcp_slowtmr(void);
/* missing declaration in lwIP */
void lwip_init();
#if LWIP_DHCP==1
extern volatile int dhcp_timoutcntr;
err_t dhcp_start(struct netif *netif);
#endif
extern int aurora_rx_main();
extern volatile int TcpFastTmrFlag;
extern volatile int TcpSlowTmrFlag;
static struct netif server_netif;
struct netif *echo_netif;
void
print_ip(char *msg, struct ip_addr *ip)
    print(msg);
    xil_printf("%d.%d.%d.%d\n\r", ip4_addr1(ip), ip4_addr2(ip),
            ip4_addr3(ip), ip4_addr4(ip));
void
print_ip_settings(struct ip_addr *ip, struct ip_addr *mask, struct ip_addr *gw)
    print_ip("Board IP: ", ip);
    print_ip("Netmask : ", mask);
    print_ip("Gateway : ", gw);
int ProgramSi5324(void);
int ProgramSfpPhy(void);
#endif
#endif
int main()
#if __aarch64__
    Xil_DCacheDisable();
#endif
    struct ip_addr ipaddr, netmask, gw;
    /* the mac address of the board. this should be unique per board */
    unsigned char mac_ethernet_address[] =
    { 0x00, 0x0a, 0x35, 0x00, 0x01, 0x02 };
    echo_netif = &server_netif;
#if XPAR_GIGE_PCS_PMA_SGMII_CORE_PRESENT == 1 || XPAR_GIGE_PCS_PMA_1000BASEX_CORE_PRESENT == 1
    ProgramSi5324();
    ProgramSfpPhy();
#endif
#endif
    init_platform();
#if LWIP_DHCP==1
    ipaddr.addr = 0;
    gw.addr = 0;
    netmask.addr = 0;
#else
    /* initliaze IP addresses to be used */
    IP4_ADDR(&ipaddr,  192, 168,   1, 10);
    IP4_ADDR(&netmask, 255, 255, 255,  0);
    IP4_ADDR(&gw,      192, 168,   1,  1);
#endif
    print_app_header();
    lwip_init();
      /* Add network interface to the netif_list, and set it as default */
    if (!xemac_add(echo_netif, &ipaddr, &netmask,
                        &gw, mac_ethernet_address,
                        PLATFORM_EMAC_BASEADDR)) {
        xil_printf("Error adding N/W interface\n\r");
        return -1;
    netif_set_default(echo_netif);
    /* now enable interrupts */
    platform_enable_interrupts();
    /* specify that the network if is up */
    netif_set_up(echo_netif);
#if (LWIP_DHCP==1)
    dhcp_start(echo_netif);
    dhcp_timoutcntr = 24;
    while(((echo_netif->ip_addr.addr) == 0) && (dhcp_timoutcntr > 0))
        xemacif_input(echo_netif);
    if (dhcp_timoutcntr <= 0) {
        if ((echo_netif->ip_addr.addr) == 0) {
            xil_printf("DHCP Timeout\r\n");
            xil_printf("Configuring default IP of 192.168.1.10\r\n");
            IP4_ADDR(&(echo_netif->ip_addr),  192, 168,   1, 10);
            IP4_ADDR(&(echo_netif->netmask), 255, 255, 255,  0);
            IP4_ADDR(&(echo_netif->gw),      192, 168,   1,  1);
    ipaddr.addr = echo_netif->ip_addr.addr;
    gw.addr = echo_netif->gw.addr;
    netmask.addr = echo_netif->netmask.addr;
#endif
    print_ip_settings(&ipaddr, &netmask, &gw);
    /* start the application (web server, rxtest, txtest, etc..) */
    /* receive and process packets */
    while (1) {
        if (TcpFastTmrFlag) {
            tcp_fasttmr();
            TcpFastTmrFlag = 0;
        if (TcpSlowTmrFlag) {
            tcp_slowtmr();
            TcpSlowTmrFlag = 0;
        transfer_data();
    /* never reached */
    cleanup_platform();
    return 0;
Echo Function
#include <stdio.h>
#include <string.h>
#include <math.h>
#include <stdlib.h>
#include "ar_rx.h"
#include "lwip/err.h"
#if defined (__arm__) || defined (__aarch64__)
#endif
char buf[32] = {0};
extern u32 DestinationBuffer[5];
int transfer_data() {
	return 0;
char *itoa(int val, int base){
 int i = 30;
for(; val && i ; --i, val /= base)
buf[i] = "0123456789abcdef"[val % base];
return &buf[i+1];
	xil_printf("\n\r\n\r-----lwIP TCP echo server ------\n\r");
	xil_printf("TCP packets sent to port 6001 will be echoed back\n\r");
err_t recv_callback(void *arg, struct tcp_pcb *tpcb,
                               struct pbuf *p, err_t err)
	int i,Status;
	Status=aurora_rx_main();
	//xil_printf("%d",DestinationBuffer);
	//u32 rx_fifo_data;
	for(i=0;i<5;i++)
		xil_printf("%d,",DestinationBuffer[i]);
	xil_printf("\n");
	    int base=10;
	    char *result={0};
	    char *result1={0};
	    char *result2={0};
	    char *result3={0};
	    char *result4={0};
	    result = itoa(DestinationBuffer[0],base);
	    result1 = itoa(DestinationBuffer[1],base);
	    result2 = itoa(DestinationBuffer[2],base);
	    result3 = itoa(DestinationBuffer[3],base);
	    result4 = itoa(DestinationBuffer[4],base);
	/* do not read the packet if we are not in ESTABLISHED state */
	if (!p) {
		tcp_close(tpcb);
		tcp_recv(tpcb, NULL);
		return ERR_OK;
	/* indicate that the packet has been received */
	tcp_recved(tpcb, p->len);
	/* echo back the payload */
	/* in this case, we assume that the payload is < TCP_SND_BUF */
	if (tcp_sndbuf(tpcb) > p->len) {
		//err = tcp_write(tpcb, p->payload, p->len, 1);
		//xil_printf("%s %s",result[0],result[1]);
		err = tcp_write(tpcb,result,2,1);
		err = tcp_write(tpcb,result1,8,1);
		err = tcp_write(tpcb,result2,6,1);
		err = tcp_write(tpcb,result3,2,1);
		err = tcp_write(tpcb,result4,2,1);
	//aurora_rx_main();
	//xil_printf("%c",ascii[0]);
	} else
		xil_printf("no space in tcp_sndbuf\n\r");
	/* free the received pbuf */
	pbuf_free(p);
	return ERR_OK;
err_t accept_callback(void *arg, struct tcp_pcb *newpcb, err_t err)
	static int connection = 1;
	/* set the receive callback for this connection */
	tcp_recv(newpcb, recv_callback);
	/* just use an integer number indicating the connection id as the
	   callback argument */
	tcp_arg(newpcb, (void*)connection);
	/* increment for subsequent accepted connections */
	connection++;
	return ERR_OK;
	struct tcp_pcb *pcb;
	err_t err;
	unsigned port = 7;
	/* create new TCP PCB structure */
	pcb = tcp_new();
	if (!pcb) {
		xil_printf("Error creating PCB. Out of Memory\n\r");
		return -1;
	/* bind to specified @port */
	err = tcp_bind(pcb, IP_ADDR_ANY, port);
	if (err != ERR_OK) {
		xil_printf("Unable to bind to port %d: err = %d\n\r", port, err);
		return -2;
	/* we do not need any arguments to callback functions */
	tcp_arg(pcb, NULL);
	/* listen for connections */
	pcb = tcp_listen(pcb);
	if (!pcb) {
		xil_printf("Out of memory while tcp_listen\n\r");
		return -3;
	/* specify callback to use for incoming connections */
	tcp_accept(pcb, accept_callback);
	xil_printf("TCP echo server started @ port %d\n\r", port);
	return 0;
Sub-Functions
#include "xil_exception.h"
#include "xstreamer.h"
#include "xllfifo.h"
#include "xstatus.h"
#include "ar_rx.h"
#undef DEBUG
XLlFifo FifoInstance;
	u32 RxWord;
	int Status;
	//xil_printf("Entering RX loop\r\n");
	//while(1)
	Status = XLlFiforx(&FifoInstance, FIFO_DEV_ID);
	if (Status != XST_SUCCESS)
		xil_printf("Axi Streaming FIFO Test Failed\n\r");
		return XST_FAILURE;
	xil_printf("Successfully ran Axi Streaming FIFO \n\r");
	return XST_SUCCESS;
int XLlFiforx(XLlFifo *InstancePtr, u16 DeviceId)
	//xil_printf("######\n\r");
	XLlFifo_Config *Config;
	int Status,n=0;
	Status = XST_SUCCESS;
	/* Initialize the Device Configuration Interface driver */
	Config = XLlFfio_LookupConfig(DeviceId);
	if (!Config)
		xil_printf("No config found for %d\r\n", DeviceId);
		return XST_FAILURE;
	Status = XLlFifo_CfgInitialize(InstancePtr, Config, Config->BaseAddress);
		xil_printf("Initialization failed\n\r");
		return Status;
	while(n<10)
	Status = RxReceive(InstancePtr, DestinationBuffer);
		xil_printf("Receiving data failed");
		return XST_FAILURE;
	n++;
	return Status;
int RxReceive (XLlFifo *InstancePtr, u32* DestinationAddr)
	int i;
	//int Status;
	u32 RxWord;
	static u32 ReceiveLength;
	ReceiveLength = (XLlFifo_iRxGetLen(InstancePtr))/WORD_SIZE;
	/* Start Receiving */
	if(ReceiveLength>0)
		//xil_printf("@@@@@@@@@ ");
	for ( i=0; i < ReceiveLength; i++)
		RxWord = 0;
		RxWord = XLlFifo_RxGetWord(InstancePtr);
		*(DestinationAddr+i) = RxWord;
		//*(DestinationAddr+i) = 10;
		xil_printf("received data : %d\n\r",*(DestinationAddr+i));
return XST_SUCCESS;
Header File
#define FIFO_DEV_ID	   	XPAR_AXI_FIFO_0_DEVICE_ID
#define WORD_SIZE 4			/* Size of words in bytes */
#define MAX_PACKET_LEN 4
#define NO_OF_PACKETS 10
#define MAX_DATA_BUFFER_SIZE NO_OF_PACKETS*MAX_PACKET_LEN
int XLlFiforx(XLlFifo *InstancePtr, u16 DeviceId);
int RxReceive(XLlFifo *InstancePtr, u32 *DestinationAddr);
PYTHON CODE
import serial.tools.list_ports
list = serial.tools.list_ports.grep('VID:PID=10C4:EA60','hwid')
connected = []
for element in list:
connected.append(element.device)
a=str(connected)
try:
port = connected[0]
baud = 115200
ser = serial.Serial(port, baud, timeout=1)
#input1.encode('UTF-8')
if ser.isOpen():
print(ser.name + ' is open...')
while (1):
out1 = ser.read()
print out1,
ser.close()
except:
pass
Thank you in advance
Observer deeksha@f7
Re: AXI EthernetLite (LWIP): Write data From FPGA Board to PC Using Python Socket command
Thanks for your response. I am new to Ethernet design. So apology me for asking me silly questions.
What you said i have tried but i am unable to connect to Terminals like Putty or Tera Terminal.
https://forums.xilinx.com/t5/General-Technical-Discussion/EthernetLite-LWIP-Echo-Unable-to-connect-with-Putty-terminal/m-p/896402#M42139
https://forums.xilinx.com/t5/Embedded-Development-Tools/KINTEX-KC705-LWIP-Ethernetlite-recv-callback-Function/m-p/896156#M46992
Please suggest me. I am really Stuck for past 10 days.
