ncalik
About * operand
Hi i have a problem with * operand in vhdl. i want to multiply two bit vector but every time program gives
ERROR:HDLParsers:808 - "U:/FPGA_VHDL/dnm/fr.vhd" Line 15. * can not have such operands in this context.
i've loaded all libraries about math but cant solve it.
thank you
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
use IEEE.math_complex.all;
use IEEE.numeric_std.all;
entity mult is
port (
X: in std_logic_vector (7 downto 0);
Y: in std_logic_vector (7 downto 0);
P: out std_logic_vector (15 downto 0)
end mult;
architecture carp of mult is
begin
P <= X * Y;
end mult;
eilert
the Problem you have has been solved some years ago here:
http://forums.xilinx.com/t5/General-Technical-Discussion/binary-multiplication-in-vhdl/m-p/3659
Besides:
Quite similare source codes, aren't they?
Is it taken  from some example in a VHDL book?
Have a nice synthesis
  Eilert
ncalik
yes i  copied codes from that page but my problem is different.
i want to see that error messages are not same.
thnx
ncalik
also i cant use + ,- , / oprands
bassman59
Historian
Historian
thank you
library IEEE;
Do NOT NOT NOT NOT use std_logic_arith. ESPECIALLY DO NOT NOT NOT use it with numeric_std.
entity mult is
port (
end mult;
begin
P <= X * Y;
end mult;
The problem is that you're trying to multiply two std_logic_vectors. std_logic_vectors do not represent numbers -- they are just vectors of bits.
You need to multiply numbers of type unsigned, signed, integer (with range) or natural (with range).
sridar
Include only the following library and package and see if it helps
library IEEE;
use ieee.std_logic_unsigned.all;
FPGA freak
bassman59
Historian
Historian
library IEEE;
NOOOOOOOOOOOOOOOOOOOOOOOOO!
Use numeric_std -- not std_logic_unsigned.
ncalik
thanks to everybody for their helps
