Voyager
Voyager
Accelerated Pynq
My understanding is that the Pynq image is 'just' a Linux OS with any Python on it for the Zynq PS.
If it was just this, I could just have any processor, so the question is, is it possible/ easy to add accelerated functions on the PL for Pynq to use access them and get that plus in speed? Any pointers/ examples how to do it?
Note: by 'accessing the PL' I don't mean writing to GPIOs and things like that but sending/ receiving data batches through AXI, etc.
Re: Accelerated Pynq
HI @johnvivm,
I recommend you to visit the web page for pynq. There is a dedicated forums for it.
Pynq will call an overlay which is basically a bitstream. You can lod you own overlay if you want to:
https://pynq.readthedocs.io/en/latest/pynq_overlays/loading_an_overlay.html
Florent
HI @johnvivm,
Florent
Voyager
Voyager
I see... lots of fluff, nothing serious. I was looking for a platform for accelerated computing and/ or ML/ NN inference.
Mentor
Mentor
@johnvivm I get the feeling that there are really two options with the Pynq:
(1) Modify the provided overlay as much as necessary, ensuring that the essentials (eg. HDMI controller) remain the same. Then recompile the overlay, update the Python code to handle any blocks that you've added, and load that onto the board.
(2) Treat the Pynq as a standard Zynq board. Scrap Python and all of the provided software, just run bare-metal or Petalinux with your own IP cores in the PL. No need to worry about keeping any of the existing PL blocks. This way is, I think, probably better-documented - but even so it's not exactly trivial.
Voyager
Voyager
(1) I don't need any HDMI for accelerated ML. I would scrap it, otherwise it's taking FPGA resources.
(2) What's the advantage in taking a Pynq overlay and scrap Python if I can start with my Zynq and set up my Linux?
Appreciate your input. If these are the options, I'm thinking Pynq is not the way for hw-accelerated ML.Or at least, there is no special advantage on it.
Mentor
Mentor
@johnvivm
(1) Excellent, that solves one problem.
(2) The only reason to use the Pynq in this case is that with the education discount, I'm pretty sure it's the cheapest Zynq 7020 board around. If you're not eligible for the education discount, don't bother.
Hi @u4223374,
You need to differenciate two things when talking about PYNQ:
  1. The framework
  2. the boards
You can do pynq on an Ultra96 board for example (or any other board).
The main advantage of pynq is that you can leverage project from the community on Zynq/ZynqMP without knowing anything about FPGA. You would only need to know python.
Then about the PYNQ board, note that with the v2 of the board, it is the same price for everyone (~120$), academic or not.
Florent
Voyager
Voyager
"you can leverage project from the community on Zynq/ZynqMP without knowing anything about FPGA"
Quite a bold statement. Lets suggest buying a plane to drive her without knowing anything about flying.
Hi @johnvivm,
I would say it is more driving a car without know anything about mechanic.
Florent
