Asynchronous sequential state machine
Do you have any documentation to recommend about the "Asynchronous  sequential state machine" design?
I have learnt several problems about it, but I still don't have any clue about how to design one.
Instructor
Instructor
You are going to hear this sooner or later, so I'll speed up the progression:
Asynchronous design is NOT supported by Xilinx.  period.  Zip Zilch.  Nada.
You can search the forums for threads discussing asynch design, there should be plenty.  You need to know that FPGA logic elements are not conventional gates -- they are static RAM lookup tables.  This means that input signal changes which should not affect the logic element output, based on a Boolean logic table, will generate output signal glitches.  In asynch design, glitches are generally a design-killer.
-- Bob Elkind
SIGNATURE:
Summary:
sorry, I forgot to tell you that: in asynchronous sequential state machine design, only one input can changes at a time. This assumption is determine to bypass the glitch.
Mentor
Mentor
You can get a glitch even with only a single input changing if you don't control the actual silicon. Which you don't when using FPGAs. A single glitch in the next-state logic will screw up your state.
Besides, I think the tools are unable to properly handle combinational cycles.
What do you want to achieve? Is this a homework assignment?
Please google your question before asking it.
If someone answers your question, mark the post with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left).
I remember reading a promise from Xilinx which said if only one input changed into a LUT, the output will not glitch but I can't find it right now. It might be interesting to check it with Xilinx folks.
I agree with you.
Are you sure that even if one input changes in the LUT will cause glitchs in the ouput?
And this is surely NOT a homework assignment, I just find an issue about AFSM(asynchronous finite state machine) disign when I was reviewing basic verilog knowledge, teacher won't assign a homeword this hard to us.
I just want to know how to design a AFSM in a clear way. Do you have some documentation to recommend to me? Thank you any way~
Gospel according to Austin says this:
The LUT is not glitch free.
Each bit input to the LUT slects a multiplexer path, in a binary tree.  So only a change to a single input is glitch free.  If more than one input changes, then due to the delay of each stage of the multiplexder tree, there may be glitches
http://forums.xilinx.com/t5/Simulation-and-Verification/Glitches-in-combinational-logic/td-p/133786
Mentor
Mentor
Interesting. But you could still get glitches, even if only a single input changes at a time, when your logic has two or more levels. Example: two LUTs A and B, the output of A is an input of B, and signal s is an input of A and B. Voilà, single input change in s results in two inputs of LUT B changing at the same time.
@wellings: Okay, so let's assume that your state change logic fits in a single level of LUTs. You still can't design sequential elements without precise control over the wire delays.
Instructor
Instructor
No.  Xilinx does not support asynchronous design.  You are on your own in this endeavour.
Well, then, you have quite a bit of work ahead of you.  I hope the end result is worth the time and effort you will be investing.  I would not be surprised if you must develop new design tools to help analyse and verify your designs.
If you are successful, you should write a book on the subject for those who wish to follow in your footsteps, as you undoubtedly will be a leader in this field.
-- Bob Elkind
SIGNATURE:
Summary:
Thank you very much for your detailed reply, and it is very helpful to me.
Aw shucks,
"Gospel according to austin" is flattering.  Thank you for your confidence in my 20 years of representing Xilinx IC designers.  Surprises me everyday to find I answered 'that' question (and tens of thousands of others).  I recommend to my colleagues, my students, to get a forum account and search here first to answer their questions.  I even look here first as I have answered so many I cannot recall them all.  You can also find the hand full of answers I got wrong and apologized for.  No one is perfect.
Now I am enjoying just being the customer.
And, yes, do not waste any time on asynchronous design.
lowearthorbit (AKA austin)
