Anonymous
Not applicable
Block RAM Monitoring
I am using Spartan-6 and using the block ram.
my design use previously initialized data from block ram to make some aritmetic operations on it and store results in the block ram also. i figured that i can use "INIT_xx" to initialize the BRAM but how i am going to dumb the BRAM data out of the fpga or at least monitor it in real time? is there a way to monitor the BRAM ?
d,
You can use the "verify" operation in IMPACT to read back the entire bitsream (into a file called impact.rbd). Just do not try to read it back if the BRAM is being used (clocked) as that may corrupt a bit or two. You could use the other port of the BRAM to fashion your own access, sand readout through logic you design (better).
Austin Lesea
Principal Engineer
Xilinx San Jose
Anonymous
Not applicable
Thanks for your help :)
