BuG: Vivado: shared objects are not executable and should *not* have +x flag
See:
    cd {{vivado_prefix}} && find -type f -executable -name "*.so*"
ELF shared objects are not executable and therefore shall not have +x flag set.
The +x flag is meant only for files which can be directly loaded/executed via exec*() syscalls.
Tags (3)
Re: BuG: Vivado: shared objects are not executable and should *not* have +x flag
@metux Oh wow. This is a horrible bug. Just imagine if someone executes a shared library by accident.
Thanks for reporting.
Hi @metux,
I general, this is not an issue for most files.  For example, if someone attempts to execute a readme file, nothing will happen even though it has x permissions.  Giving x permission is a system default and unless the umask is set to turn it off or Xilinx explicitly turns it off for a specific file it will be set.  Xilinx does not typically restrict any file permissions unless there is a need.
Florent
Okay, if you really believe that, then just execute the attached Readme file.
No, it's not. The Linux kernel doesn't automatically set +x on non-directories even w/ umask=0 - you'll have explicitly chmod() it.
And distros set the umask to some sane value (eg. 022, or 002 when using per-user groups) - see /etc/login.defs.
I'd suggest making yourself confident w/ the essiential basics of the operating system.
https://www.amazon.de/Linux-Pocket-Guide-Daniel-Barrett/dp/1491927577/ref=pd_cp_14_3?_encoding=UTF8&psc=1&refRID=TD8P9Q4H1G5YGCD9GY4F
@metux
I am confused. Are you saying there is harmful code in text files distributed with vivado?
Haven't checked everything ... but there easily can be if arbitrary text/data is interpreted as a script. That's exactly the reason why the x flags exist.
EDIT: and that's exactly the reason why the kernel doesn't set the +x flag automatically.
Very unlikely. I have submitted Vivado to Amazon and they have a super strict quality control with several anti-virus and security checks. They never caught anything.
If these files had setuid set, I would be concerned though.
Anti-Virus. *LOL*
I never talked about setuid - that's a whole different topic.
@metux this type of language is perhaps more appropriate to a teenager on Reddit. Be professional.
