Visitor jonesxu
Can I set the configuration clock for indirect downloading
When I use indirect downloading, the speed is very slow during the process that FPGA get data from EEPROM. Can I set a faster clock to speed up the process?
Teacher eteam00
Re: Can I speed up indirect programming from JTAG?
If you are referring to indirect programming of configuration memory from the JTAG port (e.g. USB Platform Cable), I do not know the answer.  Presumably this is done infrequently in design development, and an alternate approach is taken on the production line.
On the other hand, the master serial clock (aka CCLK) generated by the FPGA in the process of (master mode) configuration is programmable.
-- Bob Elkind
SIGNATURE:
Summary:
Visitor jonesxu
Re: Can I set the configuration clock for indirect downloading
And how to configure this? Sorry
Teacher eteam00
Bitgen ConfigRate setting.  In ISE:
  • click on Generate Programming File in the Processes pane.
  • Right-click to select Process Properties.
  • Select Configuration Options.
  • ConfigRate appears in the options list.
Remember:  the Configuration rate is a nominal value with a -/- 50% tolerance (for Spartan-6).  If max desired frequency is 24MHz, you must select a nominal frequency of 16MHz or lower.
-- Bob Elkind
SIGNATURE:
Summary:
Visitor jonesxu
Have found this. Thank you very much!
